It is currently Sat Jul 26, 2025 7:26 am
PostPosted: Mon Dec 17, 2007 12:07 pm
I am going to use the hanger bolt necck joint on my next guitar and had a few questions for those who have used this joint (or similar joints).
1)What size reinforcement dowel?-I am thinking 3/8" or 7/16"-hard maple
2)What size bolts? I am thinking 1/4-20.
Any suggestions would be very helpful.
Brad
PostPosted: Mon Dec 17, 2007 2:02 pm
What is a hanger bolt neck joint?
PostPosted: Mon Dec 17, 2007 5:24 pm
I was wondering the same thing...
PostPosted: Mon Dec 17, 2007 5:49 pm
Hanger bolts are what you see on wooden desks and banjos - course wood
thread on one end, machine thread on the other.
I don't know of any guitar builders who are currently using this hardware.
Most folks use a brass or steel threaded insert in the neck, and a furniture
bolt fastening the heel to the neck block. In that case, 1/4"-20 is a pretty
widely used standard.
PostPosted: Mon Dec 17, 2007 6:06 pm
I believe that both Collings and Mario use hanger bolts. Is that correct,
Mario?
PostPosted: Tue Dec 18, 2007 1:54 am
Yes,the hanger bolt is used by Collings-with a dovetail shaped tenon and by Mario with a butt joint. Both use dowel reinforcements.
I noticed that the pre-made necks that Stew-Mac sells also uses this type.
I'm sure there are others out there using it.
PostPosted: Tue Dec 18, 2007 6:42 am
You can buy them (the neck with hanger bolts) from Martin. I assume if they are selling them that way they must also be using them that way.
